pltINote SetCoordinateYExpression
Sets the expression for the y value to which the note is attached.
pltINote_handle SetCoordinateYExpression y_expression
Tcl Modify
This method is only available for coordinate notes.
- y_expression
- The expression for the x value to which the note is attached.
Returns success or an error code.
