pltIViewControl Fit
Fits the plot in the window.
pltIViewControl_handle Fit
Tcl Modify
This command zooms into or out of the graph based on the dimensions of the curve in the plot. It differs from ZoomIn or ZoomOut in that it zooms to the curve’s dimensions rather than a preset zoom. It also differs from CircleZoom in the fact that it zooms to the curve’s dimensions rather than user-given dimensions.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
w1 GetViewControlHandle vc;
vc Fit;
plot Draw;
Returns success (0) or an error code.
Keywords
XY plot
Tcl
Modify
