pltIViewControl M1
Memorizes the current view.
hwIViewControl_handle M1
Tcl Modify
This command memorizes the current view of the plot (including the exact axes dimensions). If you want to return to this view later, you can call the R1 function. The M2 and R2 functions work similarly.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc;
vc M1
Error
Returns a success (0) or an error code.
Keywords
XY plot
Tcl
Modify
