pulIMacro Apply
Applies the current macro.
pulIMacro Apply destination, hide_inputs, option, layout
Tcl Modify
This command applies the current macro.
destination
The plot in which the macro should be applied. Options include:
original
new
current
hide_inputs
1
Hides input curves.
0
Does not hide input curves.
option
Designates whether the resulting curves should all be in the same plot (in which case, the value “oneplot” should be passed) or, if each curve should be in its own plot (“NULL”). This is only used if destination is “new”.
layout
The number corresponding to the plot layout to be used. It can be any integer from 0-15 and is only used if destination is “new” and option is NULL.
hwi GetSessionHandle sess
sess GetClientManagerHandle pm plot
pm GetMacroHandle macro 1
macro AddParameter "Parameter 1"
macro SetName "New Macro 1"
macro Apply new 1 NULL 4
Returns 3 = HW_InvalidHandle if there is an invalid macro handle.
Keywords
Macro
Tcl
