pulIMacro RemoveParameter
Removes the specified parameter from the macro.
pulIMacro RemoveParameter index
Tcl Modify
This command removes the parameter with the given index from the macro.
- index
- The index of the parameter to be pasted. Must be a positive integer.
hwi GetSessionHandle sess
sess GetClientManagerHandle pm plot
pm GetMacroHandle macro 1
macro AddParameter "Parameter 1"
macro RemoveParameter 1
Returns 3 if there is an invalid macro handle.
Returns 4 if the index is less than 0 or greater than the number of parameters in the current macro.
Keywords
Macro
Tcl
