tblITableEditor GetColumnName
Returns the name of a column.
tblITableEditor_handle GetColumnName columnindex
Tcl Query
This command returns the name of the column for a given column index.
- columnindex
- Index of the column.
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set indexColumnAX [$activetableHandle GetColumnIndex AX]Errors
