tblITableEditor InsertColumnAfter
tblITableEditor_handle InsertColumnAfter
Tcl Query
None.
Adds a rule having empty or default properties and returns the corresponding rule ID.
Sets the width of the column based on the column's largest cell width.
Delete all rules present in the Table Client.
Clears any string or expression present in the specified cells.
Clears all properties (font, text color, background color or alignment) present in the specified cells.
Deletes the rule having a rule ID as an identifier.
Redraws the table editor.
Exports the table in the CSV format.
Returns the text alignment of the queried cell.
Returns the background color of the queried cell.
Returns the string or expression present in the queried cell.
Returns the font information present in the queried cell.
Returns a string containing a list of cell names that have been assigned with a string or an expression.
Returns a string containing a list of cell names that have been assigned with a property (font, text color, background color or alignment).
Returns a string containing a list of cell names that have been assigned with a rule.
Returns the Text Color of the queried cell.
Returns the string or evaluated expression present in the queried cell.
Returns the index of a column.
Returns the name of a column.
Returns value of a table cell.
Returns bottom right cell name.
Returns information about the table cells which are not empty.
Returns a list of filled rows and columns.
Returns the number of filled columns.
Returns the number of filled rows.
Returns top left cell name.
Gets the visibility status of the header area of the table.
Returns the number of columns in the table.
Returns the number of rows in the table.
Retrieves a tblIRule command object corresponding to the rule ID queried.
Returns a list of all rule IDs present in the table client.
Returns a string containing a list of all the rule IDs acting on the queried cell.
Imports the CSV file into TableView.
Sets the text alignment on the selected cell.
Sets the background color on the selected cell.
Merges cells over columns.
Sets a string or expression on the selected cell.
Sets the font information on the selected cell.
Sets the text color on the selected cell.
Sets the value of a table cell.
Show/hides the header area of the table.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
