tblITableEditor SetCellColumnSpan
Merges cells over columns.
tblITableEditor_handle SetCellColumnSpan startcell, numberOfCells
Tcl Query
This command is used to merge cells over columns.
- startcell
- The cell to you want to expand or merge with other cells. For example, B2.
- numberOfCells
- The number of cells to merge. For example, 3.
tblITableEditor SetCellColumnSpan B2 3Errors
Returns success(0) or an error code.
