vidIVideo AddOverlay
Adds a file to the Overlay Panel list, turning on the file.
vidIVideo_handle AddOverlay filename
Tcl Modify
This command adds a file to the overlay panel list, turning on the file (as an overlay). It returns the number of overlay files in the Overlay Panel list (the main file, which is not an overlay, is not included in this count).
- filename
- The file path (the exact location within the computer) of the file that you want to add as an overlay.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video AddOverlay “c:/H8gmQ.gif”;
Success (the number of overlay files) or an error message is returned.
Keywords
- Tcl
- Video
- Modify
- Create
