vidIVideo ShowTimestep
IMPORTANT: This API is now obsolete. Please refer to the vidivideo GetMediaInfoNoteHandle API to achieve this functionality. Sets whether the time step is shown.
vidIVideo_handle ShowTimestep on
Tcl Modify
This command sets whether the timestep is shown in the video or not. The timestep shows the time stamp of the video, which is displayed within the annotation note. It will be shown in the annotation note with the frame number and filename, if they are also turned on.
- on
- A true or false value.
- True
- Timestep turned on.
- False
- Timestep turned off.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video ShowTimestep true;
Keywords
- Tcl
- Video
- Modify
