vidIVideo SetTolerance
Sets the tolerance.
vidIVideo_handle SetTolerance tolerance
Tcl Modify
This command sets the tolerance. Tolerance is the allotted difference in timing between two videos. If the timing between two videos is greater than the tolerance, the second video (or third, fourth, and so on) will not play the frame(s) corresponding with that specific time.
Note: For this function to work, at least two videos must be in the page.
tolerance
The amount of time that you want the tolerance to be.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video SetTolerance 0.02;
Keywords
  • Tcl
  • Video
  • Modify
