Label Contents
  1. In the Labeling dialog, select the label to add contents to, and click the Contents tab.
    The left hand panel displays contents that were selected when the Labeling dialog was opened. To choose contents to add to the selected label, use the Query, Find, or Filter tools. The right hand panel displays contents that are in the selected label.
  2. Check contents in the left-hand panel and click Add to add them to the selected label.
  3. オプション: You can change the version of a content in the label by selecting Change to version from the labeled content コンテキストメニュー and choosing the desired version.
  4. Click 適用 or OK to update the label.
  5. オプション: To remove contents from a label, check contents in the right hand label panel and click Delete. Use the Reset button to reset the label to its last saved state.
