/INISHE/STRA_F/GLOB or /INISH3/STRA_F/GLOB
Block Format Keyword Describes the initialization strain for shell elements in the global coordinate system.
| /INISHE/STRA_F/GLOB/unit_ID or /INISH3/STRA_F/GLOB/unit_ID | |||||||||
| shell_ID | nb_integr | npg | Thick | ||||||
| T | |||||||||
Definition
| unit_ID | Optional unit
identifier. (Integer, maximum 10 digits) |
| shell_ID | Element
identifier. (Integer) |
| nb_integr | Integration point number through
the thickness. 1 (Integer) |
| npg | Number of surface quadrature points.
(Integer) |
| Thick | Shell
thickness. (Real) |
| Plane strain XX in the global
frame. (Real) |
| Plane strain YY in the global
frame. (Real) |
| Plane strain ZZ in the global
frame. (Real) |
| Shear strain XY in the global
frame. (Real) |
| Shear strain YZ in the global
frame. (Real) |
| Shear strain ZX in the global
frame. (Real) |
| T | Parametric position of the
integration points throughout the Thickness (between -1 and
1). (Real) |
- The
nb_integr should be equal to the number of
integration point N specified in the shell property.
For the case of global integration (N = 0 in the shell property for elastic material /MAT/LAW01), nb_integr = 0, but 2 thickness integration points are output.
- The npg must be set according to the formulation which is used in the shell property.
- If nb_integr ≠ 0, repeat the optional continuation lines for each integration point.
- The initial state for shells may be defined by more than one block.
