Movable Solid Domain
Reposition or modify one or more parts between design iterations while keeping the geometry of the static solid and fluid domains constant. This prevents the need to re-identify the fluid volume for each design iteration.
On the Fluids ribbon, select the Movable Solid Domain
tool.
- Select one or more parts that can be moved and modified before running a new design iteration.
- In the microdialog, assign a material.
