Specify Number of Voxels and Using Refinement Zones
- Prepare your model for a fluids analysis.
Click the Custom Fluids Run satellite icon in the
Analyze tool group.
The Run Fluids Analysis window appears.
- Enter a value for Number of voxels. The value you enter should specify a voxel size that results in at least 6 to 8 voxels across an inlet, outlet, or a narrow fluid path. Use at least 4 voxels across thin solids.
Use the Zone Refinement tool to achieve the desired
resolution.
- Click .
Select the part of the model where you would like to place the
refinement zone.
The zone refinement box appears.
- Use the white arrows to adjust the refinement zone.
