Milling
Apply a 5-axis milling constraint when a 5-axis milling machine will be used.
Apply a 5-Axis Milling Constraint
Apply a spherical draw direction, used when a machining tool needs a center of a sphere to remove material.
Milling Examples
Pumping Housing Optimization
Figure 1. Milling Constraint with Non-Design Structure Defined as Obstacle
Figure 2. Optimized Shape with 5-Axis Milling Constraint Applied—Note the Lack of Undercuts
Figure 3. Final Realized Geometry
