Change the Projection
When displaying 3D objects on a 2D plane, you can use perspective projection or orthographic projection.
Perspective Projection
Perspective projection shows distant objects as smaller and close objects as larger to provide greater realism.
![](../../../images/icons/inspire/icon_orthographic.png)
![](../../../images/figures/shared/perspective_example.png)
Orthographic Projection
Orthographic projection is useful when you want to create scale drawings with accurate measurements and proportions.
![](../../../images/icons/inspire/icon_perspective.png)
![](../../../images/figures/shared/orthographic_example.png)
