Create a Section Cut
Create and view 2D section planes of your model.
Microdialog Options
Option | Description |
Section Plane Only![]() |
By default, one side of the model is hidden. Click to hide both sides of the model and show only the section plane. |
Flip Section Cut![]() |
Reverse which side of the model is hidden. |
Move Section Cut Plane![]() |
Translate or rotate the section plane using the Move tool. |
Align to Global X, Y, Z Axis![]() |
Align the section plane to the x-, y-, or z-axis. |
Reposition section plane to model
center![]() |
Reposition the section plane to the model center. |
Keyboard Shortcuts & Mouse Controls
To | Do this |
Hide a selected section cut | H |
Add to or remove from the selection | Ctrl |
Exit the tool | Esc or right-click |
