Inspire is a concept design tool, which you can use to run structural optimization, finite element analysis, motion analysis,
and additive manufacturing analysis.
Some ribbon tabs are associated with license features. Depending upon the tab you have invoked, additional units may
be drawn. These features will be checked out for the duration of the session.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Rotate, pan, and zoom to get a better view of the model.
Rotate the View
Rotate the view using the mouse or the view cube.
Pan and Zoom
Pan and zoom using the mouse and keyboard.
Change the Mouse Controls
Change the mouse button and keystroke combinations used to rotate, pan, and zoom so they match other commonly used CAD applications.
