Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply materials,
modify the environment, and change the camera position.
The material library contains preset materials, as well as any custom materials you've saved. Understand the material
library's structure so you can more easily find materials.
You can choose from a variety of preset materials. If you can't find exactly what you want, you can choose something
similar and modify it. You can also reuse a custom material that you have previously saved.
You can choose from a variety of preset environments. If you can't find exactly what you want, you can choose something
similar and modify it. You can also reuse a custom environment that you have previously saved.
