Create Surface Probes from Polyline
Use the Probes tool to create probes based on a polyline.
                Use the Surface Probes tool to draw polylines.
                        From the Setup ribbon, click the
                                    Output
                            tool.
                        From the secondary tool set, click the surface probes of the
                                Probes tool.
- In the modeling window, select a part on which you would like to draw a polyline.
- From the guide bar, select Polyline.
                        In the modeling window, click to place polyline
                            points on the selected surfaces.
 Figure 3.
- Right-click the last created polyline point to complete the polyline.
 Points are created along the polyline.
 Figure 4.
                                    Output
                            tool.
- Optional:
                Define polyline settings in the microdialog.
                        Define the start iteration or start time.
                        To define the start time, see step 3 of Define Surface Probes.
                        Define the output interval, refinement level, or target
                            frequency.
                        To define the refinement level, see step 5 of Define Surface Probes. To define the target frequency, see step 6 of Define Surface Probes.
 Figure 5.
                Move polylines in the modeling window.
                        In the microdialog, select  . .
- Use the graphical manipulators to move the polyline.
 Figure 6.
                Edit polylines in the modeling window.
- Click along the polyline to create new polyline points.
                        Select an existing point along the polyline and use the graphical
                            manipulators to move the polyline point.
 Figure 7.
- Optional:
                Export probes.
                - From the legend in the top-left of the modeling window, right-click the active probe set and select Probes table from the context menu.
                        In the dialog, select  to export surface probes. to export surface probes.
 Restriction: Importing surface probes is not supported when type = rake.For more information, see Import, Export, and Edit Output Controls.
