Define Volume Output
Use the Volume tool to define boxes within which the results on all voxels will be written to disk at specified intervals.
You can create multiple, overlapping volume outputs. Each volume output is treated as a separate instance by the solver.
                Create volume outputs.
                        From the Setup ribbon, click the
                                    Output
                            tool.
                        From the secondary tool set, select the Volume
                            tool.
- In the modeling window, select a part on which to create a bounding volume.
                                    Output
                            tool.
- In the microdialog, define the start iteration.
- Optional:
                Define volume output settings in the microdialog.
                        Define the start iteration or start time.
                        To define the start time, see step 3 of Define Surface Probes.
                        Define the output interval, refinement level, or target
                            frequency.
                        To define the refinement level, see step 5 of Define Surface Probes. To define the target frequency, see step 6 of Define Surface Probes.
 Figure 3.
                In the microdialog, click  and specify the variables being solved for. and specify the variables being solved for.
                Edit the size of the bounding volume in the modeling window by completing one of the following:
                - Click and drag a face of the bounding volume.
 Figure 4.
- In the microdialog, click  and edit the sizing values. and edit the sizing values.
                Move the bounding volume by clicking  in
                    the microdialog and using the graphical
                    manipulators. in
                    manipulators.
 Figure 5.
                From the guide bar, complete one of the following:
                - Select  to confirm your selection and continue creating
                        volume outputs. to confirm your selection and continue creating
                        volume outputs.
- Select  to
                        confirm your selection and exit the tool. to
- Select
