::ChangeTitle
This command sets the title for the wizard dialog window. This command can be called any time after the wizard dialog has been created.
::model::mdlWizardDlg::ChangeTitle title
MotionView Tcl GUI
- title
- The text to be displayed in the title bar for the wizard dialog window.
namespace eval ::my_wizard {
    variable p_dlg ""
proc ::my_wizard::Run {} {
    set mangle [::model::GetMangle my_wizard_Run]
    variable p_dlg
    set p_dlg [::model::mdlWizardDlg wiz$mangle -width 400 -height 200 \
        -title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
    ::model::mdlWizardDlg::ChangeTitle "New Title!"
    ::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::OnClose { args } {
    variable p_dlg
    hwt::UnpostWindow $p_dlg
    return 1
::my_wizard::Run Errors
None.
