::SetCloseButtonText
This command sets the text in the button that is used to close the wizard dialog.
::model::mdlWizardDlg::SetCloseButtonText text
MotionView Tcl GUI
- text
- The text that is to be displayed in the button that closes the wizard dialog.
namespace eval ::my_wizard {
    variable p_dlg ""
proc ::my_wizard::Run {} {
    set mangle [::model::GetMangle my_wizard_Run]
    variable p_dlg
    set p_dlg [::model::mdlWizardDlg wiz$mangle -width 600 -height 400 \
        -title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
    ::model::mdlWizardDlg::SetCloseButtonText "Done"
    ::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::OnClose { args } {
    variable p_dlg
    hwt::UnpostWindow $p_dlg
    return 1
::my_wizard::Run Errors
None.
