::GetEditBarFrame
This command gets the frame that contains edit bar for the wizard dialog.
::model::mdlWizardDlg::GetEditBarFrame
MotionView Tcl GUI
namespace eval ::my_wizard {
    variable p_dlg ""
proc ::my_wizard::Run {} {
    set mangle [::model::GetMangle my_wizard_Run]
    variable p_dlg
    set p_dlg [::model::mdlWizardDlg wiz$mangle -width 400 -height 400 –show_eb \
        -title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
    set frm [::model::mdlWizardDlg::GetButtonFrame $p_dlg]
    ::model::mdlWizardDlg::AddButtonToActionFrame $frm btnShow 4 "Show" ::my_wizard::OnShowButton
    ::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::OnShowButton {} {
    set frm [::model::mdlWizardDlg::GetEditBarFrame]
    if { [$frm cget -bg] == "red" } {
            $frm config -bg blue
      } else {
            $frm config -bg red
proc ::my_wizard::OnClose { args } {
    variable p_dlg
    hwt::UnpostWindow $p_dlg
    return 1
::my_wizard::RunErrors
None.
