::GetDialogFrame
This command gets the frame that contains the contents for each page of the wizard dialog. If the frame has not yet been created, it is created when this command is called.
::model::mdlWizardDlg::GetDialogFrame
MotionView Tcl GUI
namespace eval ::my_wizard {
    variable p_dlg ""
proc ::my_wizard::Run {} {
    set mangle [::model::GetMangle my_wizard_Run]
    variable p_dlg
    set p_dlg [::model::mdlWizardDlg wiz$mangle -width 400 -height 400 \
        -title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
    set frm [::model::mdlWizardDlg::GetButtonFrame $p_dlg]
    ::model::mdlWizardDlg::AddButtonToActionFrame $frm btnShow 4 "Show" ::my_wizard::OnShowButton
    ::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::OnShowButton {} {
    set frm [::model::mdlWizardDlg::GetDialogFrame]
    if { [$frm cget -bg] == "red" } {
            $frm config -bg blue
      } else {
            $frm config -bg red
proc ::my_wizard::OnClose { args } {
    variable p_dlg
    hwt::UnpostWindow $p_dlg
    return 1
::my_wizard::RunErrors
None.
