::PostMessage
This command posts a message to the message log for the wizard dialog. When the wizard dialog is closed, these messages are copied to the main application message log.
::model::mdlWizardDlg::PostMessage msg type
MotionView Tcl GUI
- msg
- The message that is to be displayed in the message log for the wizard dialog.
- type
- The type of message being posted to the message log. It is normally either “Error”, “Warning”, or “Info”, but can be any arbitrary text.
namespace eval ::my_wizard {
    variable p_dlg ""
proc ::my_wizard::Run {} {
    set mangle [::model::GetMangle my_wizard_Run]
    variable p_dlg
    set p_dlg [::model::mdlWizardDlg wiz$mangle -width 600 -height 400 -show_eb \
        -title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
    set frm [::model::mdlWizardDlg::GetButtonFrame $p_dlg]
    ::model::mdlWizardDlg::AddButtonToActionFrame $frm btnShow 4 "Time" ::my_wizard::OnTimeButton
    ::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::OnTimeButton {} {
	::model::mdlWizardDlg::PostMessage [clock format [clock seconds]] Info
proc ::my_wizard::OnClose { args } {
    variable p_dlg
    hwt::UnpostWindow $p_dlg
    return 1
::my_wizard::RunErrors
None.
