LATPRM, LATSUP
Bulk Data Entry Defines the maximum volume fraction of the lattice support region for Topology Optimization with Overhang constraints.
| Parameter | Values | Description |
| LATSUP | 0.0 ≤ Real ≤ 1.0 No default |
This allows for the
generation of medium-dense elements for support regions which may
subsequently be converted into lattice regions. Note: The volume
fraction is recommended to be set between 0.1 and
0.4.
