SS-T: 4060 Frequency Response Analysis
Create frequency response analysis in SimSolid for a vertical wind turbine assembly.
- Purpose
- SimSolid performs meshless structural
analysis that works on full featured parts and assemblies, is tolerant of
geometric imperfections, and runs in seconds to minutes. In this tutorial,
you will do the following:
- Use modal analysis results to create a frequency response analysis.
- Model Description
- The following model file is needed for this tutorial:
- Frequency.ssp
Open Project
- Start a new SimSolid session.
On the main window toolbar, click Open Project
- In the Open project file dialog, choose Frequency.ssp
- Click OK.
Create Modal Analysis
Create Immovable Support
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings.
- In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
- Click OK.
Run Analysis
- On the Project Tree, open the Analysis Workbench.
Click
(Solve).
Review Modes
Create Frequency Response Analysis
Define Frequency Function
Define Loads
Run Analysis
Click
(Solve).
