SS-T: 4015 Non-linear Incremental Analysis
Review incremental non-linear buckling.
- Prerequisites
- Some features used in this tutorial are only available in SimSolid Advanced version. Please switch to Advanced to complete this tutorial.
- Purpose
- In this tutorial, you will do the following:
- Create geometric non-linear analysis.
- Review incremental non-linear buckling results.
- Model Description
- The following file is needed for this tutorial:
- hinge_beam.x_b
Import Geometry
Create Virtual Connectors
Assign Materials
Create Structural Non-linear Analysis
Create Immovable Support
Create Displacement Load
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings.
- In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
- Click OK.
