View Load History
View results at load increments.
- In the Project Tree, open a Geometric non-linear Analysis Workbench.
                On the workbench toolbar, click
 (Results plot).
                Select the desired plot.
                The load steps where instability occurs are highlighted in red in the Load History dialog. You can click any step to view the deformed shape at the associated load percentage.
                Review results in the Load History window.
- Choose a step to view the results at that load percentage.
 - Use the up and down arrows on your keyboard to move between steps.
 - Click Animate history to animate the load history.
 - In the Animation speed dialog, change the value to modify the spped of the animation.
 - Click Show history graph to view a graph of the desired response.
