Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Reset all the preferences to the default settings.
Set to the default settings of Access Web. By resetting to the
default settings, you will lose all the saved preferences. For example, you will lose
the Saved Filter Options, Columns added to the list view, default job action settings,
enabled persistence behavior, notification preference.
Click .
Select Preferences.
Access Web Preferences is displayed.
Click Diagnosis in the left panel.
The Diagnosis panel is displayed.
Click Reset All button to set to the default
settings.
