Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Following are the prerequisites for performing job actions:
Administrator has to configure job actions in JSON format for the registered
PAS server.
The configured JSON format job action script has to be placed at:
PA_HOME/config/pa/
An action is similar to an application action, without being specific to an
application or a job state. However, an action is specific to a server, is available
for any job and which can be executed for a job.
In this example, an action, Qstat of Job, has been defined for this server, therefore
when you click Actions, the option Qstat of Job will be available.
Click the Jobs tab located in the upper left-hand of the
page.
The Job Monitoring view is displayed containing a list of the jobs that
have been submitted.
Select a job from the list and click Actions.
Click Qstat of Job from the list.
Action Menu Input Dialog Box is displayed with the output directory of
the job that is selected.
Note: The Action Menu Input Dialog Box will not be
displayed if the generic action script does not require any input from the
user. The generic action will be performed on the job and the output will be
displayed.
Note: If you had selected multiple jobs, then the output
directory will be blank.
Enter the working directory.
Click Run
The action list performed on the Job will be displayed.
Perform one of the following options:
Click Close to go back to Job Monitoring list.
Click Back to go back to Action List menu to perform an action.
