Remove old or unwanted jobs.
Only jobs that have completed or have failed can be removed. Removing a job, deletes
the job from the PAS , but the job files will be
available in PAS .
Click the Jobs tab located in the upper left-hand of the page.
The Job Monitoring view is displayed containing a list of the jobs that
have been submitted.
Tip: Use the filter on the left to view only
completed or failed jobs.
Right-click a completed or failed job.
Tip:
You can select multiple jobs to delete. Select the first job by clicking its name and
hold down CTRL and select each job by clicking its name.
Click Delete .
The Delete Job dialog box is displayed.
Figure 1. Delete Job
Perform one of the following options:
Click Yes to remove the job.
Select Delete related folders and files in the staging
area? check box and click Yes to
remove the job from the staging area.
