View Job Information
View the job information as provided by the PAS.
- Summary Tab - View job metadata, view job result files using the text, plot and image viewer.
- Input Tab - View the input files that are provided for the job.
- Output Tab - View the job result files that are generated after the job is completed.
- Running Folder Tab - View the files of a running job.
- Details Tab - View the job properties information like Job ID, Job Name, CPUs requested, Application, CPU percent used, and Memory used.
- Diagnostics Tab - View the job diagnostics information which helps you to troubleshoot the issues.
- Console Tab - This tab is displayed only when Custom Actions are performed on the job.
