Use the Physics tool to define the solar radiation settings used in the simulation. Here you can specify the global parameters for
solar radiation heat flux.
Use the Model tool to create, delete, and import/export solar radiation models. These models are utilized to calculate the solar
heat flux on applied surfaces.
Use the Surface tool to apply solar radiation properties to selected surfaces. Solar heat flux is calculated on these surfaces based
on the defined solar radiation model.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Set Up the Solar Radiation Settings
Use the Physics tool to define the solar radiation settings used in the simulation. Here you can specify the global parameters for solar radiation heat flux.
Define Solar Radiation Models
Use the Model tool to create, delete, and import/export solar radiation models. These models are utilized to calculate the solar heat flux on applied surfaces.
Assign Solar Radiation to Surfaces
Use the Surface tool to apply solar radiation properties to selected surfaces. Solar heat flux is calculated on these surfaces based on the defined solar radiation model.
