Use the Surface Finish Library tool to create, delete, and import/export surface finish models. A surface finish definition is an ideal grey-surface
emissivity model used in the radiation equation.
Use the Opening tool to apply radiation boundary conditions at openings. A radiation opening definition provides a method of fully
enclosing a fluid domain that is not surrounded by walls. This condition is appropriate for inlet and outlet
type boundary surfaces.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Set Up the Thermal Radiation Settings
Use the Physics tool to turn on thermal radiation physics and define the thermal radiation settings used in the simulation.
Define Surface Finish Models
Use the Surface Finish Library tool to create, delete, and import/export surface finish models. A surface finish definition is an ideal grey-surface emissivity model used in the radiation equation.
Assign Surface Finishes
Use the Surface Finish tool to apply surface finish properties to selected surfaces.
Define External Radiation
Use the External tool to apply external radiation heat transfer to selected surfaces or thin solids.
Define Radiation at Openings
Use the Opening tool to apply radiation boundary conditions at openings. A radiation opening definition provides a method of fully enclosing a fluid domain that is not surrounded by walls. This condition is appropriate for inlet and outlet type boundary surfaces.
Define Radiation Output
Use the Output tool to apply radiation output settings to selected surfaces.
