Define Boundary Layer Settings
Use the Boundary Layer tool to define boundary layer mesh settings on selected surfaces.
Select the surfaces on which to apply the mesh
control in the following ways:
- While in the Mesh ribbon, select surfaces, then right-click and select from the context menu.
- From the Mesh ribbon, click the
Boundary Layer
tool.
Select surfaces.
- In the dialog, define boundary layer options.
From the guide bar, execute the command in the following
ways:
- Click to confirm your selection and remain in the
tool.
This allows you to continue creating instances and helps you visualize and edit instances with the legend.
- Click to confirm your selection and exit the tool.
tool.
