Define Mesh Controls Using Groups
Use the Advanced Create dialog in the Setup Browser to create mesh controls for selected entity groups.
View new features for HyperMesh CFD 2023.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Use the Mesh Controls tools to define size controls, refinements, and boundary layer controls to be considered for surface and volume meshing.
Use the Surface tool to define local mesh settings on selected surfaces.
Use the Edge tool to define local mesh settings on selected edges.
Use the Edge Layer tool to generate layers from selected edges during surface meshing.
Use the Gap tool to define mesh refinement settings based on gaps between surfaces.
Use the Angle tool to define mesh refinement settings based on angles between surfaces.
Use the Boundary Layer tool to define boundary layer mesh settings on selected surfaces.
Use the Volume Mesh tool to define local volume mesh sizes on individual solids. You can also choose different volume mesh settings, such as defining layers on thin regions and quality controls.
Use the Extrusion tool to create hex mesh on extruded geometry. This is useful for creating mesh for 2D simulations and layered mesh on simplified geometry.
Use the Zones tool to define mesh refinement settings by shape. These controls provide the capability to get mesh refinement on surfaces enclosed in defined boxes, spheres, and cylinders.
Use the No Boundary Layer tool to define surfaces on which boundary layers should not be created nor imprinted.
Use the context menu on the legend to deactivate mesh controls. This excludes them from consideration when processing the solution.
Create mesh on individual surfaces interactively and edit elements to fix issues or improve quality.
Use the Repair tool to find, review, and fix issues in the mesh.
Use the Volume tool to run a surface + volume mesh on the entire model.
Use the Quality Report tool to check the quality of surface and volume mesh.
Remove all mesh from the model.
Use the Element Quality view to review element quality while simultaneously editing your model.
Use the Fix tool to improve the quality of an FE (discrete/mesh) model.
Prepare your model and run the simulation.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
ON THIS PAGE
ON THIS PAGE
