STREAMLINE
Streamlines are massless particles moving along a path with a velocity tangent to the streamline at every point.
STREAMLINE(“name”) { parameters}
Qualifier
User-given name
- calculation_direction (enum)
- Streamlines can be integrated either backward (upstream) or (forward) downstream or in both directions.
- time_limit (real)
- Limits the length of the streamline when the streamline is calculated either backward or forward. It does not apply if both directions are selected.
- display_seeds (boolean)
- When activated, the seed locations will be displayed as spheres.
- seed_type (enum)
- Method of identifying seed locations
- seed_file (string)
- If seed type = from_file is selected, path to the file containing seeds.
- normal_direction (enum)
- Used when seed_type=rectangular
- x_center (real)
- x-coordinate of centerpoint of rectangle. Used when seed_type=rectangular.
- y_center (real)
- y-coordinate of centerpoint of rectangle. Used when seed_type=rectangular.
- z_center (real)
- z-coordinate of centerpoint of rectangle. Used when seed_type=rectangular.
- x_length (real)
- Length of rectangle in the x direction. Used when seed_type=rectangular.
- y_length (real)
- Length of rectangle in the y direction. Used when seed_type=rectangular.
- z_length (real)
- Length of rectangle in the z direction. Used when seed_type=rectangular.
- x_seeds (integer)
- Number of seeds equally spaced along the rectangle in the x direction. Used when seed_type=rectangular.
- y_seeds (integer)
- Number of seeds equally spaced along the rectangle in the y direction. Used when seed_type=rectangular.
- z_seeds (integer)
- Number of seeds equally spaced along the rectangle in the z direction. Used when seed_type=rectangular.
- x_1 (real)
- x location of first seed of rake. Used with seed_type = rake.
- y_1 (real)
- y location of first seed of rake. Used with seed_type = rake.
- z_1 (real)
- z location of first seed of rake. Used with seed_type = rake.
- x_2 (real)
- x location of second seed of rake. Used with seed_type = rake.
- y_2 (real)
- y location of second seed of rake. Used with seed_type = rake.
- z_2 (real)
- z location of second seed of rake. Used with seed_type = rake.
- num_seeds (integer)
- Number of seeds to place between two specified points for rake
- name (string)
- User-given name of the command. The instance of a given command is referenced using this parameter.
- display_type
- Control the display style of the streamline
- color_type (enum)
- Method used to set the display color
- constant_color (enum)
- Display the streamline as a constant color
- num_contours (integer)
- Number of contour lines to be displayed in legend
- contour_function (string)
- Scalar quantity to be displayed on streamline (pressure, velocity, and so on)
- line_thickness (enum)
- Thickness of lines for mesh display and feature line display
- vector_function (string)
- Function to use for vector display
- reference_part (string)
- Part used as reference to display more realistic streamline scales
- export (boolean)
- Flag to export data in ASCII format
- active_flag (boolean)
- Read and process the command or ignore it
- legend_display (boolean)
- Flag to toggle on or off the visibility of the legend
- legend_title (string)
- Add a title to the legend
- legend_subtitle (string)
- Subtitle of legend
- num_labels (integer)
- Number of labels used in legend
- legend_min (real)
- Minimum value in legend
- legend_max (real)
- Maximum value in legend
- legend_use_local (boolean)
- Flag to indicate to use values for max and min of legend based on data available for specific visualization.
- num_decimal_places (integer)
- Number of decimal places to display in legend
- legend_orientation (enum)
- Specify orientation of the legend
- legend_location (enum)
- Location of the legend on the image
- invert_color_map (boolean)
- Option to invert the colors of the colormap
- filled_contours (boolean)
- Option to display surface with constant colors within a polygon of the surface. If the scalar values change within a polygon, the polygon will then be split and colored appropriately for that polygon.
- colormap_name (enum)
- Colormap name to use for displaying the scalar function values
- log_scale (boolean)
- When selected, the scalar will be colored using a logarithmic scale instead of a standard scale.
- specification_type (enumerated)
- Method used to define the parameters of the CUT_PLANE instance.
- restart_file (string)
- Path to the FieldView restart file that will be used to define the cut plane. All parameters to define the plane are read from the restart file.
- rake_id (real)
- The rake id within the FieldView restart file to extract the streamline parameters from.
- legend_location_type (enum)
- This option determines how the legend location will be specified.
STREAMLINE("upstream rake"){
calculation_direction = forward
time_limit = "_none"
display_seeds = off
seed_type = rake
normal_direction = x
x_1 = (xMax-xMin)*.2 + xMin
y_1 = yMax*.99
z_1 = (zMax-zMin)/2.0 + zMin
x_2 = (xMax-xMin)*.2 + xMin
y_2 = yMin*.99
z_2 = (zMax-zMin)/2.0 + zMin
num_seeds = nSeeds**2.0
line_thickness = thin
color_type = contour
contour_function = "velocity_magnitude"
legend_display = on
legend_subtitle = "_none"
vector_function = "velocity"
num_labels = 2
legend_use_local = off
legend_min = .6*meanVel
legend_max = 2.5*meanVel
display_type = complete
