VARIABLE
Expressions are used to define a quantity in terms of variables that are defined using the VARIABLE command or in terms of built in math functions (sin, cos, tan, and so on). The order in which commands appear is not important. Variable x could be a function of variable y, even though it appears afterward in the input file.
VARIABLE{ parameters}
Qualifier
This command has no qualifier.
variable_name (string)
Given name of the variable
expression (string)
Number or mathematical expression that defines this variable
active_flag (boolean)
Read and process the command or ignore it
VARIABLE{
     variable_name      = meanVel
     expression         = 0.2265
VARIABLE{
     variable_name      = nSeeds
     expression         = 15
