Heat Exchanger
Create a heat exchanger component.
hx = vwt.HeatExchanger()
Methods
setInlets(partId)
Assign part as an Inlet for the heat exchanger
setOutlets(partId)
Assign part as an Outlet for the heat exchanger
setWalls(partId)
Assign part as a Wall of the heat exchanger
Attributes
inertialCoefficient
Inertial porous media coefficient to model the heat exchanger
viscousCoefficient
Viscous porous media coefficient to model the heat exchanger
permeabilityDirection
Permeability direction - vector type
For example, (1,0,0)
