Part Properties
Edit properties.
Methods
- getBaffle(partId)
- Check if part is a baffle
- setBaffle(partId, True)
- Set part as baffle
- getPassivePart(partId)
- Check if part is marked as passive for force computation
- setPassivePart(partId, True)
- Set part as not passive for force computation
- getWallModelOverride(partId)
- setWallModelOverride(partId, True)
- getWallModelCouplingType(partId)
- setWallModelCouplingType(partId, str)
- Set coupling type to One Way, Two Way, or None
- getWallModelIntensity(partId)
- setWallModelIntensity(partId, value)
