xy axisvertical
Copy, create, cut, delete, edit, and paste an axis, either defined by a range or the marked entity.
xy axisvertical copy <mark|marked|range>
xy axisvertical create <mark|marked|range>
xy axisvertical cut <mark|marked|range>
xy axisvertical delete <mark|marked|range>
xy axisvertical edit <mark|marked|range>
xy axisvertical paste <mark|marked|range>
Arguments
copy
Copies the selected entity.
mark
mark=<marklabel>
marked
<true/false>.
True applies the action to the marked entity.
range
Define the range for the entity you want to apply the action to.
create
Create a datum.
mark
mark=<marklabel>
marked
<true/false>.
range
cut
Removes the selected entity from the Plot Browser and deletes it from the current session.
mark
mark=<marklabel>
marked
<true/false>.
range
delete
Deleted the selected entity.
mark
mark=<marklabel>
marked
<true/false>.
range
edit
Edit the selected entity's properties.
mark
mark=<marklabel>
marked
<true/false>.
range
Editable properties include:
  • associatedaxis=<axisname>
  • font=<font>
  • fontsize=<fontsize>
  • label=label
  • labellocation=<location>
  • layer=<layerid>
  • linecolor=<color>
  • linestyle=<style>
  • linethickness=<thickness>
  • name=<name>
  • position = <position>
  • visibility=<true/false>
paste
Pastes the selected entity into a window.
mark
mark=<marklabel>
marked
<true/false>.
range
Define the window range for the entity you want to apply the action to.
Examples
Edit the axis properties:
xy axisvertical edit range="p:all w:all i:all" format=Scientific
xy axisvertical edit range="p:all w:all i:all" color=2
