xy datumhorizontal
Copy, create, cut, delete, edit, and paste datum lines, either defined by a range or the marked entity.
xy datumhorizontal copy <mark|marked|range>
xy datumhorizontal create <mark|marked|range> <name>=<value>
xy datumhorizontal cut <mark|marked|range>
xy datumhorizontal delete <mark|marked|range>
xy datumhorizontal edit <mark|marked|range>
xy datumhorizontal paste <mark|marked|range>
Arguments
- create
- Create a horizontal datum by specifying datum attributes.
- copy
- Copies the selected entity.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- Define the range for the entity you want to apply the action to.
- cut
- Removes the selected entity from the Plot Browser and
deletes it from the current session.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- delete
- Deleted the selected entity.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- edit
- Edit the selected entity's properties.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- paste
- Pastes the selected entity into a window.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- Define the window range for the entity you want to apply the action to.
Examples
xy datumhorizontal create range= "p:1 w:1 i:6" name= "Datum 8" linecolor=36 linestyle= 2 linethickness= 2 visibility= true font= "Arial 8 normal roman" associatedaxis= 1 label= Datum New
xy datumhorizontal delete range="p:all w:all i:all"
xy datumhorizontal edit range="p:1 w:all i:all" linecolor=2
