xy header
Edit header properties, either defined by a range or the marked entity.
xy header edit <mark|marked|range>
Arguments
edit
Edit the selected entity's properties.
mark
mark=<marklabel>
marked
<true/false>.
True applies the action to the marked entity.
range
Define the range for the entity you want to apply the action to.
Editable properties include:
  • alignment=<alignment>
  • color=<color>
  • primaryfont=<font>
  • primaryfontsize=<fontsize>
  • secondaryfont=<font>
  • secondaryfontsize=<fontsize>
  • tertiaryfont=<font>
  • tertiaryfontsize=<fontsize>
  • text=<text>
  • visibility=<true/false>
Examples
Edit footer properties:
xy header edit range="p:1 w:all" color=2
