axisgradient=<true/false>
<true/false>
Turn the axis gradient on or off.
bgcolor=<color>
Select a background color from the color picker.
charttype=<xy/bar/complex/polar>
The chart type: xy, bar, complex, or polar.
curseralwaysvisible=<true/false>
<true/false>
Turn the cursor on or off.
cursorcurvecolor=<true/false>
<true/false>
true displays the cursor the same color
as the curve's color. Otherwise, it's black.
cursorcurvestyle=<true/false>
<true/false>
true changes the line style of the
animation cursor (solid, dashed, and so on) to match the curve’s
style.
cursorheight =<value>
Enter a value to determine the cursor's height, a percentage of
the window height.
cursorthickness=<value>
Enter a value between 1-5 to determine the cursor's
thickness.
gridlinecolor=<color>
Select a gridline color from the color picker.
gridlinetransparency=<value>
Enter a value between 0-1 to display the gridline's
transparency.
invalidpointmode=<bridge/gap>
If a CSV file contains blank spaces, select
Bridge or
Gap.
Bridge handles the blank spaces by creating
a bridge in the plotted curve.
Gap handles the blank spaces by displaying
a gap in the plotted curve.
lockaxis=<never/atimport/always>
Choose from never,
atimport, or
always.
- Never
- The selected axis is automatically scaled to fit new
curves or bar charts that are added to the axis.
- At Import
- The selected axis remains scaled to fit the curve(s)
currently assigned to it and it is not scaled to fit
new curves.
- Always
- The axes are not fit with any of the operations and
will always be locked.
publishwindow=<true/false>
true publishes the current window
contents.
uniformaspectratio=<true/false>
true activates uniform aspect ratio.
zerolinecolor=<color>
Select a color from the color picker to change the zeroline
color.
