::ListProcedures
This command is used retrieve all the public exposed methods for a given namespace. Each method will be displayed in a new line.
::model::ListProcedures argNamespace
MotionView Tcl
argNamespace
You need to pass the namespace as an argument, for which you need to get all the public exposed methods.
::model::ListProcedures "::model::mdlOption"
On successful execution of the command, it will list down all the methods exposed to the users for a given namespace.
