hwIAVIExportOptions SetFrameRate
Sets the frame rate used when exporting AVI files.
hwIAVIExportOptions_handle SetFrameRate value
Tcl Modify
This parameter is used when exporting AVI files from either the video or animation clients during HTML export.
- value
- The frame rate (frames per second) to be used when exporting AVI files.
mySessionName GetAVIExportOptionsHandle myAviOptions
myAviOptions SetFrameRate 25.0Error
- HW_InvalidHandle
- The handle used to invoke the method is no longer valid.
- HW_InvalidArgs
- The value for the frame rate is out of the valid range (must be greater than 0).
