hwIClientInfo GetName
Finds the name of the client.
hwIClientInfo_handle GetName
Tcl Query
This command finds the name of the client the you are using. It differs from GetDisplayName in that it finds the name of the client, rather than the program that the client uses (or its display name). This name is displayed in the tab next to the Session tab if the GUI.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetClientInfoHandle ci Plot;
ci GetName;
Error
The name or an error message is returned.
Keywords
Tcl
Query
